If you soak in diesel remember to degrease before you apply the penetrant of choice because most will not work on oily or greasy surfaces .Thanks folks. I’m going to try a hybrid plan… first a good cleaning then I’ll soak the drive end in a bucket of diesel. Then I’ll try the vice method with a heavy dose of liquid wrench applied under the sprocket. I’ll update in a week.
Still wanting to argue...Those bearings are not on the input shaft.
And it can be different that is why the model is needed. Once that is posted we all can be on the same page.Look at the shaft he’s trying to remove, to me it sure looks different than the one you posted. That being said, seeing your this forums resident expert and love to point out other members mistakes, I guess I must be wrong again. You can start ignoring me again, because I’m not going away, and I’ve argued with guys smarter than you.
