I have a Craftsmen lawnmower model 917.370601. It’s equipped with a Honda engine model GCV 160 LAO S3A NH1 with a Kehnin #G2ZC2BH24 carburetor.
The only way I can get the thing started is by giving it a 1/2 sec. shot of starting fluid. After it starts, it surges for about 20 seconds and then settles down to continuous operation. I’ve let it run for 15 minutes. After that, I tried to restart it but wouldn’t without the shot of starter fluid.
There is no primer bulb. It has a choke with a curious mode of operation. You move the choke lever to the choke position. When you pull the brake, handle down and, before you can pull the starter rope, the choke lever begins to move to the open position. (I’ve attached a photo of the linkage below.)
When the cable from the brake handle is pulled to the right, the actuating pin is also pulled to the right until it contacts the right hand end of the slot in the choke release lever. This happens when the brake handle is pulled approximately 1/4 of it’s travel. As soon as the lever begins to move, the choke begins to open. I’ve bent the actuating pin to the left so that it just touches the left end of the slot thereby delaying the movement of the lever until the brake handle is almost at the end of its travel. I did this because I thought the choke was opening to soon and not being effective.
I’ve replaced the air filter, spark plug, drained the gas tank and carburetor bowl and refilled it 90 octane ethanol free gas. I’ve thoroughly cleaned the carburetor and arranged the gaskets per the diagram I have. None of that helped.
About the choke. I’ve even wired it closed and the engine still won’t start
I’ve been dealing with small engines for 60 years but this one’s got me stymied.
James Birke
North Tonawanda NY.
If anyone has had a similar experience, I sure would like to know how you fixed it!
