You'll want to verify 2 separate events to be able to trust the results:Does anyone when, in relation to the TDC mark on the flywheel, are the valves supposed to open and close?
1. With a screwdriver down the sparkplug hole, verify that the piston is indeed at TDC when the mark says so. (This will insure you can believe the marks.)
2. Then, with the engine at TDC between the exhaust and intake strokes (both valves slightly open) verify that the clearance goes out of each valve at approximately the same distance from TDC. (IOW, if the Intake gets tight about 1" away from the TDC mark, then the Exhaust will get tight about 1" away, but on the opposite side of TDC.) This is because...
