Westman
- Jun 14, 2020
- Threads
- 0
- 53
Just a matter of time before my rear adjusters start locking my rear wheels again since I didn't put oil/grease seals on the wheel side of the assembly(s). I cleaned up my old adjusters and purchased two 1/2"x5/8"x3/4" bronze oillite bushings for $3.75 ea. These slid perfectly into the raceway of the adjusters. No drilling out was necessary. I epoxied the bushings and oil/grease seals on both sides. I used JB Weld epoxy, the kind that sets in 5-6 hrs in case I messed up and needed to wipe off excess, etc. 5 minute set time on most epoxies leaves little room for error that's why I went with the longer setting stuff. I'll set these aside to dry and then re-install in a couple days. We will have three different methods to arrive at a fix. Civic, using ball bearings. Briantii using needle bearings and the bronze oilite bushings I'm using. With sealed bearings/bushings, I expect all three methods to produce good results (fingers crossed). My method may be shorter lived depending on how long the bushings hold up. There will be a 1/4" gap inside the raceway between the seal and the bushing on one side. I'll fill that up with CV2 grease before inserting the axle. That should give the bushing another source of lubrication besides the oil impregnated in the bushing (Oillite). I'll report back once I get these installed and throw in a scale measurement as well. Peace...
