Briggs and Stratton Warped PLASTIC Intake Manifolfd
briggs
I agree. Bring back the Briggs Lhead twin engines.
yup yup i do agree...I have 3 inteck motors at the shop with holes in the block and they were all low k and i have a 17.5 hp single cyl that has a knock to it at low speed all had good oil in them but some how the all blew up i got lots of parts lol:thumbsup: might be able to throw something together soon
davbell22602
I got a 25hp intek that was on a Scotts/John Deere 2546 in pieces in couple 5 gallon buckets. It has 2 broken rods. Unfortunely you cant buy just rods. That part number subs to a crankshaft kit. So I sold what I could off the mower then scrapped rest of it.
tybilly
I love the L head twins,my dad was a gm tech and loved the Vegas(trying not to turn this thread into automotive.lol)
briggs
me to lol u must have seen my Pro street race car too I sold it some guy offered me stupid money for it rolling .....I want another 73 i like them better
truckinguy
I had the same thing happen to me this month. My 22hp Endurance Briggs was back firing while mowing and surging some. I took the carb off cleaned it still did it. I bought a new carb and noticed the warp as I was inspecting the assembly before I put back on the engine. I wish I caught it the first time. HA. Well being mowing season I took the carb off and applied a good bead of gasket maker and that did the trick. Runs so strong now.
I see they have a revised manifold but it looks like the same engineering at the point of the warp so I am leery of spending the money and time to replace it with something of the same. I only had 30 hrs on it. I see the Professional series has a metal manifold and wonder if that will work. The carb for this Pro series is the same Nikki 2 barrel so I am hopeful. If I feel rich soon I may order one and try it. There is different gaskets for the manifold to the heads but they won't effect anything. In my new carb kit I got gaskets like that.
Does anyone feel the new revised intake is any better?
truckinguy
I bought a metal maniforld from a Briggs Professional and using the spacer for that motor and the restriction plate and gaskets required on my Husqvarna Endurance motor.
The engine runs great. Everything lined up perfect. Including the flywheel shroud and all throttle and choke links.
Mad Mackie
This is good to know, my first impression when I had the new 30 HP Pro Turf engine out of the box and the 26 HP ELS engine next to it, I thought that the aluminum manifold would not fit on the ELS engine. I had replaced the plastic manifold on my 26 ELS engine and as I torqued the carb bolts to spec I watched as the plastic manifold warped. I sealed it with high temp silicone, but it was too late as permanent damage had already occurred in the engine.
truckinguy
Because of the linkage hookup,the top motor air filter shroud I had to put a spacer in between the manifold and the carb. At first I thought this would effect the engine's performance,etc. But it didn't which I'm happy about of course. This spacer brought it to the same specs/distance as the plastic/carb combo OEM. They must use the spacer for this purpose on other models. Also on my carb I have the restriction metal gasket between the carb and manifold. So I have 3 gaskets and the metal restriction plate between the carb and manifold. It lined up perfect. Runs perfect I must say. I didn't think that combo would really work. I don't know what the restriction metal plate does or doesn't do but not all have it between the carb and manifold it seems.
wekjo
If anyone knows of an aluminum manifold to replace this plastic one, please provide vendor and part number. Check out funny mower guy on youtube "Taryl fixes all". He points out the manifold issue on this engine, it warps AND cracks along the heat seam where the top and bottom are joined in manufacture; and the little hose for pulse pump dries and cracks. I replaced the little hose and slathered epoxy along the seam. Seems to have helped smooth things out at high rpms. Little hose can be had for less than 10 bucks on ebay. Takes longer to remove hood on mower to get at this area than to do these little repairs.
