If some of you learn what an in/lb wrench is for would help. Carb to manifold 65 in/lbs (5.4 ft/lbs); Manifold to cylinder head 80 in/lbs (6.7 ft/lbs). Over tightening the screws is a leading cause of the warpage. Yes heat plays a part too.
AmenI agree. Bring back the Briggs Lhead twin engines.
That's all good but these are just lawnmower engines and many people working on them don't have such tools (yes I do). The problem is really with Brigg's choice of materials and not the guy just trying to get his mower going.If some of you learn what an in/lb wrench is for would help. Carb to manifold 65 in/lbs (5.4 ft/lbs); Manifold to cylinder head 80 in/lbs (6.7 ft/lbs). Over tightening the screws is a leading cause of the warpage. Yes heat plays a part too.
Or a heat gun clamped to a flat surface. Not the end of the world guys.I'm kinda surprised that no one here has tried to sandpaper the plastic manifold flat? ... I'm just trying to find out if that actually holds up over time?
Ideally this would work, but this would make the intake not line up with the engine shroud and maybe also some linkage problemsMake your own wooden carb spacer. Keep the heat off the plastic. Old school car racer trick. More plenum volume and insulate the carb from percolating the fuel.
Wow, I didn't know that spare part floating around in my shed was worth that much!That's all good but these are just lawnmower engines and many people working on them don't have such tools (yes I do). The problem is really with Brigg's choice of materials and not the guy just trying to get his mower going.
Anyway one Aluminium Manifold is now a quarter the cost of a whole replacement engine, so a tried and tested method of plastic manifold repair makes a lot of sense.
