Skyharbor106
- Sep 12, 2020
- 3
- 15
I have a small 158cc B&S engine that came with a 2006 Bolens push mower. The manual has some instructions how to clean the foam air filter. It says to clean with dish detergent, squeeze dry and then soak, saturate with motor oil. To me that seems counterproductive. Why would I clean the filter with soapy water and then saturate with motor oil? It does say in the manual that if you don't saturate the filter, engine damage can occur. To be honest, I have never done this step and the engine runs fine. What is the purpose of the oil bath?
Also, this engine does not have a visible fuel filter. Can a small engine like this just not have a fuel filter?
Thanks for your help.
