SeniorCitizen
- Aug 28, 2010
- Threads
- 143
- 2,307
-----------------------------------------------------------------------------------------------------------------Last weekend I disconnected the ground wire attached to the ignition armature from a clip type fitting (this fitting was beneath the carb.) that appeared loose and held the ground wire close to the cowling while pulling the cord.
If the wire you mention is a small wire and goes up under the cowling, that's the kill wire that grounds the mag to kill the engine when you turn the key to stop. Other switches, safety switches in particular, like the pto - blade engagement, can kill the spark to the plug as well via that small wire going under the cowling.
I would suggest removing that ground wire from its terminal again and see if that allows spark at the spark plug when grounding the side of the plug on the head. If that allows spark to the plug it will probably run. To kill it touch that little ground wire back to metal.
