- Nov 29, 2014
- 64
- 24,705
Not quite with you here@bertsmobile1, you suggested I check the governor. I did this, as suggested at half throttle, and the throttle plate (2) does not pivot when I move the governor loop with the throttle lever. Note, when I pivot the plate manually with my fingers waggling the governor, the engine performs as it should, speeding up and down accordingly. See video link below.
I removed the shroud and cleaned out the debris that collected.
With the throttle set at 1/2 speed the engine speed should increase when you push that loop towards the spring
The further you push the loop the harder the governor should be pushing back against your finger
Is this happening ?
