Daquiri_briggs
- Feb 15, 2016
- 50
Okay, I think I will have to go buy a "file" from home depot today. I dont think I have anything that will grind it down.
They are called wet stones, for sharpening knives and the like. You put either oil or water on the surface when using to help prevent clogging of the pores in the stone. Get a course as well as a fine, because otherwise it will be time consuming. The exhaust valve stem is so hard that it gives grinding stones a run for their money sometimes. You can also use wet/dry sandpaper, but I would also find some course grid in that also if possible to cut down on time to do the valves.
