Normally pretty good with mechanics, I've got one that's totally stumped me. My Briggs & Stratton VTwin 22HP will run for about 6-7 minutes, then the governor starts hunting and it eventually dies, even under no load. What's odd is that if you choke it, it'll start right back up (hunting still), then die again. Here's what I've tried already:
At this point I'm at a loss. Not much has turned up on searches so hoping this forum might have some fresh views. Super frustrating because it starts up and mows beautifully... for 6 minutes, at which point it brings out the worst in me.
Any ideas?
- Replaced fuel filter, spark plugs, and air filter, changed oil and oil filter
- Drained fuel and replaced to make sure nothing weird going on there
- Tried running it with air filter off after it's hunting, no difference
- Removed gas cap while hunting, no difference (it's not a vented cap, this design has a hose from the air intake back into the tank for pressure intake - so it's always clean air). Checked hose and it's clear.
- Replaced fuel pump and vacuum hose
- Replaced carb (Nikki carb o-ring seal and jets seem to be a common problem)
- Replaced both magneto armatures (ignition coils), which include attached spark plug wires. Set gap to the specs.
- Checked exhaust while hunting - plenty of air movement coming off
Any ideas?
