So, I replaced the battery and charged the new one appropriately. The engine turns over WEAKLY, but doesn't really want to start - it will eventually, just barely. With a brand new charged battery, the voltage DROPS from 13.5 to 6 V while turning the key.
Would a bad starter cause a voltage drop?
If your dropping over half of your available voltage ... My first place to look is a bad cable, either the positive OR the negative.. the starter solenoid could be about to fail or any of the connections that the battery cables attach.
You can check all of them by taking a 'good' set of heavy jumper cables and go directly from the battery to the starter...
Hook the negative to the engine or the mounting bolt for the starter...
then carefully contact the positive jumper cable to the large terminal on the starter...
This will spin the engine, (so be careful)...
If it turns over exactly as bad as it did using the factory wiring ... THEN you have a bad starter...
If it spins it as it should then you have one of the earlier mentioned problems...
I doubt it is the starter... if you were dropping all that voltage in the starter it would be smoking hot within 15 to 20 seconds... but if you check it with jumper cables Directly to the starter, you will know immediately what the problem is... :smile:KennyV
