- Sep 24, 2017
- Threads
- 280
- 6,789
flip the engine over, the sump cover/oil pan, is on the bottom.
Are you talking about honing the cylinder wall before removing the piston? Or after?I once had a similar problem with an old Wheel Horse, I used various grades of flapper wheels and time, but it did a great job, so great that I kept on going until I was 0.010 over. I think that old guy is still going strong.
After...and replacing rings with .010 oversized rings.Are you talking about honing the cylinder wall before removing the piston? Or after?
