can i make my own if so what material can i use? also how can i find the part number for this??
Try an aluminum flat washer with an appropriate size hole. ACE hardware or similar may have one.can i make my own if so what material can i use? also how can i find the part number for this??
Just go to a small engine repair shop. Not a dealer.
Ask them for a bowl nut gasket. Most shops will give it to you.
Or ace hardware sells them for like $0.49
Yes for sure and no big deal doing it that way, but the OP was asking about making a gasket. Which I will do at times if I need a gasket other getting into my car and looking for one which is more of a job then just making a gasket. The nearest parts store to my shop is a 6 mile drive and at that they may not have one.
Was just giving him another option.
