- Nov 29, 2014
- 65
- 24,995
Re: B&S 24hp 2cyl 445677-2188-G5 won't start - Craftsmen YT4000 tractor-out of ideas!
I have stayed out of this one as every man & his dog seemed to be posting and it just get confusing.
SO you removed the engine, flipped it upside down ripped off the sump, replaced the gasket then flipped it back up and installed it in the mower.
It cranks but does not start, just gives some small backfires .
So
1) did you pull the flywheel or leave it on ?
2) why were you replacing the gaskets ?
now for the diagnosis.
pull the blower housing off & set it aside
Remover both plugs and get some new ones.
remove the kill wires from the magneto coils
put a SHORT shot of starter fluid into each plug hole then replace the plugs ( do one at a time )
crank the engine
If it runs a few revolutions then repeat, with each side by itself and one plug removed.
Again if it runs a few revolutions then you have confirmed the ignition timing is good & the exhaust valves are working
Do the same, both cylinders then one at a time but spraying the SHORT SHOTS of carb cleaner down the throat of the carb
If it runs on the carb cleaner then that shows the inlet valves are working.
If you can keep the engine running with repeated short shots down the carb then the problem is in the mower or the fuel system.
Replace the kill wires & repeat test
Engine does not run then you have a wiring problem in the mower.
If all this fails the whip off the rocker covers.
And check the operation of the valves with respect to the piston position.
So
crank the engine
