Re: B&S 24hp 2cyl 445677-2188-G5 won't start - Craftsmen YT4000 tractor-out of ideas!
No sir even with starter fluid no attempt to fire the only thing that happens is after cranking for quite a bit a small backfire. I am by no means an expert on small engines but I'm a pretty good troubleshooter and I am totally stumped
I was understanding you did NOT have spark..
If you have spark now...
If the engine turns over...
The mower should start with a very small shot of starting fluid...with choke open
It may die right a way...but it should start...
Will it?
