It really depends on the manufacture so do have access to these fill holes especially some the new mowers. But it best to prime off (Bench) the tractor if possible but you must have the equipment to spin the input pulley up to 3000 rpms. I will be testing using a 500 rpm drill later here as that is currently the only large hand drill I have. I believe that drill will work as I hand primed the last hydro.
