MyGrassHasCrabs
- Sep 18, 2017
- 47
Run until engine starves no with no fuel.
Concur with replies about ethanol and stabilizers but I would also add the suggestion of using quality synthetic engine oil that has and is the S.A.E. viscosity the owner's manual shows.Live in SW Virginia with a 4 month moderately cold winter and I keep my Cub Cadet 42 tractor in a shed with a push Honda mower. The tractor battery stays in tact but I do keep it connected to a battery tender.
Is it better to complete run the engines dry of fuel (with an empty tank) or, as I have read elsewhere, fill the tanks with conditioned fuel to minimize any possible condensation?
The Honda push mower has a fuel shut off valve ( as does my Honda generator) however the tractor does not, in case any of that matters? Thanks
Bob:I can only express my experience.......how long has there been ethanol gas? 15-20 years? Never, ever, have had any issue with mowers, lawn tractors, snow blowers, chain saws, weed whackers........ I only started using some
Stabil a couple years ago because a neighbor was moving and gave me a couple of bottles. So I suppose others have had different experiences, but me? None, at all. Couple pulls next season and never an issue. Maybe I am just luckly. So, no one has gotten any of my money, and the last time I had repairs done by a shop? Let's see? That would be never. I recognize that if someone does not want to risk having to pay for repairs that are potentially caused by ethanol fuel, their lowest overall cost is paying for presumably preventive measures. i understand that, but my experience and common sense observations do not indicate ethanol fuels are all that bad if you use the fuel before it sits for long periods of time. 30 days seems trival as an issue in my experience. I have had gallon jugs sit over the winter in the garage when it didnt snow much and when put into the spring time ready to go lawn mower with its last fall gas, couple pulls and off and running. I guess everyone's experience is different. I have never heard a good explanation of why ethanol gas can't sit for a short while or why its bad in its fresh condition for any engine. The only explanations I have gotten is......I was told its bad......
Drain the E10 from the tanks of the Cub and the Honda. Refill with Ethanol free gas. Run it for a while to get the efree gas through the fuel pump and carb. You're done. Just start the tractor every three weeks or so over the winter to keep seals moist. You're done and will have a simple start up come spring. Go have a beer.Live in SW Virginia with a 4 month moderately cold winter and I keep my Cub Cadet 42 tractor in a shed with a push Honda mower. The tractor battery stays in tact but I do keep it connected to a battery tender.
If its on YouTube, it must be accurate......Bob:
If you watch the many Utube small engine Repair guys like tarryl and Dony boy and B. Pender you will see the gel like substance that forms in the float bowl, emulsion tube etc. Glad you have not had a problem. I don't risk it in Southern Ontario. Perhaps you live in a less humid area. A tightly sealed Full Container is best for storage.
The craziness to ban ethanol fuels are those who have no ability to read and learn, however that and those people are why this country has been heading downhill at an ever increasing rate!With an almost full tank there is minimal air which contains moisture. Turn off or block Fuel line and run it til it stalls. You did good. The Lieberals have banned Ethanol Free fuel in all of Canada. Idiots.
Agreed, however fuel without ethanol (corn) is more efficient and produces better results than what the government has mandated and as long as I can easily obtain it, it’s my preferred fuel.I can only express my experience.......how long has there been ethanol gas? 15-20 years? Never, ever, have had any issue with mowers, lawn tractors, snow blowers, chain saws, weed whackers........ I only started using some
