McTurff
- Jul 12, 2025
- 122
I had the original carb on it when I first got it running but put another carb onCouple questions:
Can you hold the carb linkage at idle and get a slow idle? (I'm talking about holding the carb shaft against the idle set screw)
Next: You mention that yours runs at high rpm even with the dash control set at slow. If so you have a throttle plate control problem instead of a governor problem.
In post #31 and 33 I posted that I my opposed twins will slow idle with the dash control set at slow and the governor not even needed. The governor arm is actually locked out mechanically and not even used at slow idle on mine,(cannot even move the governor arm with hand because it's locked mechanically at low idle) but does have a governored idle part way up on the dash throttle.
My engine model types and codes are as follows 422707 1263 01, code 9403105A and 42E707 2631 E1 code 9811235B and both use the same governor arm and throttle plate and springs.
Your engine shows on parts lists that it uses the same governor arm and throttle plate as my engines. (but Briggs does have other type throttle plates and governor arms for the opposed twins and they must be kept matched for correct mechanical governor/throttle operation)
Post up some good pictures of your governor arm and throttle plate. I see that Briggs has different type throttle plates and governor arms for the opposed twins is why I ask about pictures of yours.
Also post up close up pictures of yours throttle plate when at idle and also a full throttle.
CHINA
I will take a look at it tomorrow I cleaned up the original carb to put back on i don't know if it is actually the right carb??
Anyway i will get some pics!
I do have another Briggs carburetor looks like it could work it is from a twin engine pretty sure it was an opposed twin!
It has #s on it so I should look and see if it will work on my engine!
I keep posting this
The engine runs wild with no springs or tension on governor
And I thought that would mean it is not functioning???
Should come to idle??
Thanks for more info and I will report!
