24HP V-Twin B&S - Fault driving me CRAZY!
Boobala
Ok... I've fitted the Ali manifold with new gaskets aaaannnnnddddddd..... The fault is STILL THE SAME :thumbdown::thumbdown::thumbdown::confused2::confused2::confused2:
So unless someone can talk me out of it ...I... GIVE... UP!!!! :mad: And out of despair here's my current chain of thought ...
  • It's just a sneeze .... not a full backfire.
  • After 2 years of this sneezing I have stripped the engine down and uncovered minimal wear and tear.
  • The issue is not detectable when I wear earmuffs :laughing:
  • Sometime in life you just have to admit defeat :ashamed:
What's your thoughts gents?
All the best.
Neo
WELLLLLL ... !!!SAQ.jpg...1530392614.jpg ,,, :laughing:..:laughing:
Scrubcadet10
Moderator
Staff member
Or this....... :laughing::laughing:
Neo7
Don't tempt me guys :laughing:
I mowed the lawn with this engine onboard my Husky yesterday. And was reminded of what brought this problem to a head last time. When the engine gets hot there a lot more popping going on and it gets to a point where the engine dies and wont start for 10 mins. So despite the indication of "problem found" I had with the Single Barrel Carb I can't help asking...
Am I really on the right track? ... Could this be an ignition issue???
So what haven't I checked, change or assumed is working OK? ..... The Flywheel???
Scrubcadet10
Moderator
Staff member
have you ever contacted Briggs about the issue???
Briggs support ?
Go to your nearest authorised Briggs dealer .
Briggs dealer , go to the equipment supplier
Equipment supplier, we have no customer service go see briggs
Neo7
Briggs support ?
And I'd rather put the money into a Chonda!
BTW Bert...Is it possible to get a Chonda with a Long Drive Shaft (100mm/4inch)?... As my Husky needs that.
Boobala
