2023 Liberty Z 42 Hydraulic Oil Change Help
7394
My 48" Liberty does not have that issue. I can easily set & cut in all heights..
And FYI, with all tires properly inflated, set the cut height @ (say for example 3 inches). Then go under & measure blade tips to the level ground parked on, & most won't be accurately set to say 3 inches cut height.. Close but not precise.
But mine are, I adjusted them to be correct.
7394
Even my former Toro 4260 was off.
