18 HP B&S Charging System
The good news is you have a 9 amp stator. The reg/rect you ordered will work fine with this stator. As said previously, just make sure when you mount it, you make a good ground connection with its case. Obviously, remove both diodes there now when you install it!
Amazon finally delivered the regulator rectifier. I would have at least expected a simple explanation of which wire goes to the stator! I assume the Red wire connects to battery power and the Yellow wire connects to the stator. Can anyone confirm this for me?
I got the regulator rectifier installed today. It works as it should. Normal voltage charging is happening! Thanks again for all the assistance.
