primerbulb120
Moderator
- Nov 3, 2014
- 43
- 1,315
Rivets, you tell me that my mower is set up wrong. If an authorized dealer listed on the Toro website set my mower up wrong, I am not going to recommend purchasing a Toro. If my mower is set up correctly and is functioning as intended, I am disappointed with its performance and cannot recommend it. Either way, I have a good reason not to recommend Toro.
I may not know how the personal pace system works, but you said in post number 7:
"I work for a Toro dealer and set up the PP mowers. Yours is properly if the wheels do not roll when pulled backwards."
I can't mow my lawn without pulling my mower backwards. Or am I supposed to mow what I can going forward and then mow a sizable portion of my lawn with a weed trimmer? If I use the mower as intended, I can't mow a sizable portion of my lawn. Are Personal Pace mowers intended for mowing only simple lawns? If so, I must rank them below all mowers that are capable of mowing an awkwardly shaped lawn. Since I want to mow all of my lawn with my mower, I don't use it as Toro recommends.
Do you have an awkwardly shaped lawn? If so, do you mow it with a Toro Personal Pace?
As for mowing speed, it varies from person to person. I consider my mower too slow, whereas you consider yours to have plenty of speed. I do not jog through my lawn on a regular basis, because my mower will not let me. I did say that I would if it went that fast. I can understand that most people prefer to walk rather than jog while mowing, and I do not criticize Toro for making their mowers as slow as they do.
I do not claim to understand all the ins and outs of my mower, but as a consumer I would not recommend the Toro Personal Pace.
If the mowers are evenly matched, how about the engines. I prefer the Honda. It is easier to refuel, and its parts are cheaper compared to those of the Briggs and Stratton.
