Ric
Everything I use is one 2.6 oz. bottle of oil for 1 gallon of gas (50:1). As you said, it is nice having everything the same ratio.
This is the 2.6 oz. bottle of PowerBlend oil I use: View attachment 10692
I'm not trying to tell you to change oil or anything because the Echo Power blend is good oil, but you know that Stihl sells oil in that size container also and you mite want to give it a try once, I think you'll find it runs a lot cleaner. I don't know how much oil you use but if you're buying your oil in that size container your spending about ten times as much money as you need to spend.
