Carscw
txzrider said:An explorer is not an f150 w/o the bed... it is a ranger w/o the bed. F150 and expeditions I believe are on the same frame. less than 3000 pounds does not sound like alot to pull until you need to stop! Make sure your brakes and tires are in good shape. Also make sure you practice with the trailer. If you are just now getting your license, everything takes longer with a trailer, from crossing intersections to entering the highway onramp. Take care and good luck.
Not sure where you got your info It is a f150 If it was a ranger it would be a lot smaller hello.
All the suspension parts are the same part numbers as the f150 the rear end , engine , and tranny are the same.
You do know that a ranger is a small truck
Sent from my iPhone using LMF
