And should I get A tranny cooler? The transmission went bad under 150,000 miles and it was completely rebuilt under a year ago. So it basically has a new tranny. Should I get better shocks?
Dang, when I saw the title of this thread I thought you were going to use the Explorer to mow the yard. :laughing:
boston said:And should I get A tranny cooler? The transmission went bad under 150,000 miles and it was completely rebuilt under a year ago. So it basically has a new tranny. Should I get better shocks?
I had visions of a 72" or 84" belly mower or a 3 point hitch finishing mower. I can see it now.....mowing in 100 degree heat with the A/C on or mulching leaves in the fall with a little heat going.
Oh great, now I have all these ideas running through my head......A Suzuki Sidekick or Geo Tracker as the base. Drive everything hydraulically, including the rear axle. Use a 6' belly mower and two 5' bat wing decks. I guess it's a good thing my project budget is next to non-existant, and what little I do have is tied up in a golf cart project right now.
But I digress and return this thread to its original topic. :thumbsup:
Do u think I should get a weight distributing hitch? The underside of the truck is very rusty so I might have to replace the shocks. I know for sure the leaf springs need to be replaced cuz their rusting out
I wasn't sure if it had the cooler I guess it does. I think ill install a tranny temp gauge so I don't over heat it
