lawn mower fanatic
I mulch them, sweep them up with the lawn sweeper, and dump them in the burn pile.
Does the lawn sweeper get all of the leaves up (as much as bagging them?) because some people on here say it doesn't work as well.
I had a cousin who used to take DRY leaves and cram them up under his trailer in the fall and that acted like insulation and kept the pipes from freezing! They would remove some of the skirts on the trailer to get the leaves in, then replace the metal panels. Then in the Spring he'd rake them out and mulch them on the lawn. Sounds Eco Friendly to me.
DaveTN said:I had a cousin who used to take DRY leaves and cram them up under his trailer in the fall and that acted like insulation and kept the pipes from freezing! They would remove some of the skirts on the trailer to get the leaves in, then replace the metal panels. Then in the Spring he'd rake them out and mulch them on the lawn. Sounds Eco Friendly to me.
Never thought of doing this I bet it works good.
Sent from my iPhone using LMF
