Auto Doc's
- Sep 7, 2024
- Threads
- 12
- 968
Fuel flow looks good from the line, make sure to check the carb fuel inlet nipple and float seat are for any trash lodge in them. It only takes a small flake of debris to create headaches when it comes to carburetors.
I noticed the idle air screw has not been removed (Black restrictor cap on the side). Take a pair of side cutters and cut down alongside that black cap. Get the cap off and carefully screw the metal needle inward to count how many turns until it stops lightly.
Then remove it and blow through the passage and make sure it is cleared out. Install the needle fully seated and count the turns to get it back close to the original adjustment setting that you counted earlier
Once everything is cleaned and dried, reassemble it and see what happens. You may have to adjust the needle out or in slightly, but it should run much better without all the surging up and down.
