rickpaulos
I posted in the cub cadet form but maybe this is a better place.
Kohler Command 12.5
Got the Cub Cadet 1320 hydro out the shed after all winter.
New battery today.
Starts - make a horrendous hammering sound - blowing oil & smoke out the exhaust. dies in 10 seconds.
700 hours. Oil & filter changed every 100 hours or so.
My guess is a stuck piston ring. We were in a drought area last year so it probably sat longer this winter than usual.
What to do?
Repair or replace?
It's a horizontal piston engine so pouring something in to try to free up a ring means turning this heavy mower on it's side or end or taking the motor out which is half way to tearing it apart.
Looking around for used motors I see these were installed different brands of mowers. Would they all be interchangeable? Same bolt pattern and shaft size? Fuel line and throttle hook up? Should I look for one that was from a Cub Cadet?
I'm somewhat mechanically inclined and I have had push mowers apart before. Several used motors for $400 ish.
Or is there something at Harbor Freight or Northern Tool that might fit?
Kohler Command 12.5
New battery today.
What to do?
Repair or replace?
