Its Me
- Apr 11, 2011
- Threads
- 2
- 114
Rick9, I have a mower repair shop at home, retired been in the repairs business, 50 years, that is a simple fix, I am also a machinist, gosh have to be to be able to save customers with machining and welding on them is a daily job, all that needs to be done is machine the top and bottom bushing, cut a lite spiral on both pieces so that the grease with follow the spiral grove, you should be able to find a tinker machinist where you live, be a good customer if he does not have the material you buy it, oil tight bronze is an excellent choice for your application, when you get it fixed make sure you grease often, don't make the bushing out of something hard that will cause wear of the pivot pen, all else fails you can get with me and ship it I will machine it for you, Joe
