Obsolete SCAG Idler arm assembly #46145
Now that you a replacement part you have time the work on straightening the old part if you wish to take the time and effort.
A lot pf things are repairable if only someone took the time and was willing to learn something new. But it seems a lot of our techs have just got on the lazy side of things.
Just had a JD to a customer that his didn't have an oil pump and to ignore the flashing oil pressure light. All he had to do was to either realize an with an oil filter has an oil pump or looked up the engine's IPL. But I don't mind as I now have a new customer.
tschwarting
Hi all,
I need to replace a worn out idler arm for my 52" Scag walk behind SWZ-14KA built in 1990.
The hub portion has been damaged by letting the bronze bushing wear out very badly.
Problem is: The part needed is the 46145 but it is no longer available at Scag and they do not provide any alternate idler arm to use.
So I am sending this message to see if anyone may have this arm assembly to sell. Used or new.
Please let me know if you have this part on hand or know another source.
Any help will be greatly appreciated.
Thanks so much.
Richard
There is a place here in New York called newburgh power equipment and they've got a huge building FULL of parts. Their contact information is: phone # is 845 564 6960. Or 800 834 6960 Email is http://www.newburghpower.com
I'd be highly surprised if they couldn't help you out.
Good luck!
jviews12
Easy to machine a bushing if you have a lathe. I do not have one, so cannot volunteer.
