Pebbles2020
- Aug 31, 2021
- Threads
- 2
- 12
Hi all,
Last mow I noticed the drive pedal when engaged in reverse was very slow, however fwd operated normally regardless of when the blade deck was on.
Today, the mower started fine and after about 10 minutes of normal use both fwd and in reverse the drive pedal stopped working completely. The belt is tight, the pedal seems to have normal tension, the fan also has expected tension when I manually turn it (gently) and the back pin freely moves the lever in n out. The thing simply won’t move when engaging the pedal and I am stuck.
Any thoughts before I spend the $ for service?
