- Dec 7, 2022
- 2,252
Or bend the tabs out carefully, install belt, and tap tabs back into position.This is when the engine has to be unbolted and moved so the belt can be remove and installed. It is one of my pains with MTD mot using anti-seize compound on these shafts and pulleys. I have had to destroy several pulleys just so I could replace leaking oil seals on Cub Cadet ZTRs.
Luckily most time the drive pulley will slip down and it get reinstalled with anti-seize so the next person don't have to deal with the pulley being stuck.
