Husqvarna LTX248XD with Kawasaki Engine - Downhill Stalling
Hydestone
My mower is losing power when going downhill, not sure what is causing the issue. It runs fine going uphill and on the flat, but when I am going downhill, the engine will suddenly lose power and sometimes stall out. When I start it back up, I usually get a puff of black smoke. I changed the oil, all good. Fuel is good too.
If I keep the accelerator pinned when going downhill, it doesn't seem to stall out. But if it's 90% down, it will stall. Also, if I go downhill without the blades engaged, it is less likely to stall. Here are some videos of the problem. In the downhill video, it starts to stall but recovers, then ultimately stalls.
Any thoughts on what is causing the issue?
Uphill:
Downhill:
Almost acts like the fuel pickup tube in the tank isn't submerged when going downhill.
The tank was probably 90% full when I recorded that video. I was wondering if there was some stuff in the fuel line that blocked fuel intake when tilted down and slightly to the left, but the line is clean.
If the fuel outlet on the tank is on the bottom and toward the front could possibly have something inside the fuel tank blocking fuel flow when downhill and to the left.
Water in the float bowl will do this .
Some times a bare patch on the kill wire can touch the block at different angles
Also the carb solenoid ground wire can do the same thing if the ground screw is loose .
Get a pair of orange in line spark testers and fit them
Drive down hill and watch for the orange light becoming erratic as you descend
I doubt that it is an electrical problem, it has the halmark of a fuel problem but the more you eliminate the fewer problems it can be
You can also swap the fuel solenoid for a short bolt to rule the solenoid out .
Have you opened the Carb? I encountered a situation where a carb float could (re)installed backward and that would cause stalling.
