I also store pump gas and use a stabilizer all year (marine type) . I get less work because most of the customers back with less fuel problems. They finally took my advice. Keep the fuel out of the direct sun you will have less problems.The great ethanol vs non-ethanol debate rages on!!!!
Just like oil, oil filters, spark plugs use what gas makes you happy. I have about 30 things with gas engines that all run regular pump gas and i have stored regular gas in cans for over a year. Never had an issue. I guess i am just luckier than most.
2cycle engines must us 89 octane or better, has less heat than 87.Wow, I never Knew I was putting alcohol (Heet) in my gas to get rid of the ethanol in the gas I bought in the first place, and then bragging about how well it works, I was obviously thinking out loud, it just doesn't make sense, Thank you for all the info
How many gallons do you actually go through? I usually burn about 5 gallons per mowing cycle. That is an extra $5. Certainly worth it for the lack of aggravation I have experienced in the past. The two stroke stuff preforms much better on gasoline as well.Is it really worth the extra price (Over a dollar a gallon extra) to get ethanol free fuel for mowers? I have a 18 hp Briggs & Stratton engine engine on my riding mower, I have a small small push mower and I have a 2-cycle weedeater. I’m in south Alabama, 65 miles from the coast. The past several years, I’ve cranked up the weedeater during the off growing season just to polish up what I may not have weed-eated earlier – just to run it for a little bit. I may or may not do that for the push mower. The riding mower is used to drag limbs to a burn pile so it gets cranked every so often in the ‘cold’ season. We’re not long out of growing season and we don’t have really cold winters.
I’m just wondering if there’s something I can do different or is there just no reason for the non-ethynol fuel at my location.
I appreciate your thoughts and time!
Bull****. Stop spreading crap. The effective compression ratio of any utility two stroke is around 6 to 7 to one, no where near detonation territory and added octane only has the effect of draining your bank account faster.2cycle engines must us 89 octane or better, has less heat than 87.
And you are wrong. Several 2 cycle engines are in the area of 10-11:1 There are a lot of 2 cycle engines that won't even fire at the ratios you are trying to sell us. Go do your research and stop spreading false information.Bull****. Stop spreading crap. The effective compression ratio of any utility two stroke is around 6 to 7 to one, no where near detonation territory and added octane only has the effect of draining your bank account faster.
Get an education......
