Hollingerw19
 - Apr 30, 2019
- Threads
 - 1
 - 2
It's possible they done that way to scam people. I had fair share of dealership ripoffs my dad's hustlerturf raptor SD. They charged him $1400 for a new PTO and figured out the engine shakes. I have rebuilt metal and plastic carburetors. I will never run E10 or above fuels for the plastic only E0. E0 to E10 is for the metal carburetors.Friend has a Troy Bilt walk-behind Mower with a 6.75 Briggs Engine. The only way he could start it was using starting fluid. He took it to a Mower notable shop and they said the Carburetor is bad. They put on a new OEM carburetor. He got it back Home and it wouldn't start any better. He took it back and they said the Engine compression was low so it needs a short-block. They didn't offer any compensation for the previous repair. Before tossing it, he asked me to take a look and I found Auto-choke was holding the butterfly wide open when Engine cold. Removed the Engine shroud and discovered the plastic Vane for the Auto-Choke was warped causing it to hit the underside of the Shroud. I heated it up with a Torch and lowered it a bit. Put the shroud on and it moved freely. Now the Mower starts on the first pull. It seemed simple to me as I fixed it while he waited. I'm assuming the Repair Shop tested the Mower with the Shroud off?
