7394
- Sep 5, 2014
- Threads
- 90
- 5,148
OK, once I filled till it came out side ports @ 56.6 oz each, & capped them Let it sit overnight, & rechecked next day, it took some more in each, then did purge process over & over. let sit overnight again.. REchecked levels, & added a slight bit, so about 63 oz in each. Bottom line is Clean Clean & Clean. Wipe above the oil filters (like show shine rag, before you would even begin to loosen them. Any dirt at all could wreck them.
And after good purge processes, it can take a lil more fluid. HG tech told me this..
