My neighbor, who does small engine repairs on the side, put fresh fuel (always ethanol free ) with Stabil in his lawn tractor before winter storage and runs the tractor around his yard to distribute the fuel and that’s it, he has never had a problem with start up in the spring.
That seems like the simplest method along with a trickle charger for the battery!
That said, I’m sure others have different methods as I’ve also called the shop where I purchased the mower and there recommendation was to either run it dry or add fresh stabilized fuel to the tank so obviously there’s more than one correct answer?
