oldgearhead
- Jul 4, 2018
- 37
I have received excellent help here for all my previous issues with this mower. Just a rant - DONE with Dixie Choppers.
Here are the details of my mower:
1) Videos online showing individuals installing a screw and pulling out the seal with either pliers or a hammer (like removing a nail). Is this the best way of removing the seal on the lower end of the mower? Better procedures?
2) How do you keep the engine from turning when removing the screw, holding the pulleys? Is this the same method when installing the screw and what torque do you suggest ?
3) What is the best method or tool to use for installing the new seal?
3) Do the pulleys (clutch for blades and drive) require a puller to remove or can you remove them without one? If a puller is required can you suggest what you use for this removal?
Thanks for any assistance. And just as an update from previous posts, the accelerator cable has made it so far without fail, the idler spring is working great, when replacing the idler spring I noticed the LH Parker pulley was not running true. I replaced the LH Parker as I could not find anyone to rebuild (long story). After I replaced the tranny the RH now is leaking and the engine seal is leaking. LOL, what a summer it has been.
Thank you for assisting and listening,
- 2017 Dixie Chopper Blackhawk HP 2560 KOE purchased in 2018
- Kohler EZT 740 S/N: 4702504833
