- Feb 19, 2020
- Threads
- 121
- 12,895
Okay now things are getting a little confusing.
Here is the different terminals.
Amp 179975-1
Amp 42281-1
Aptiv (F56) 2965867-L
Your current housing uses the AMP 42281-1 terminal.
The Rotary housing uses the Aptiv 2965867-L terminal
And the Amp 179975-1 may fit either one but there is one problem. The Amp 179975-1 will lock on the switch terminal tabs and not be locked in either housing. This can be a problem later as the connector housing will come off but terminal will stay lock on the switch tabs.
from the above the last terminal [Amp 179975-1] you link is on the Left. The F56 [Aptiv 2965867-L] is in the Center. The other terminal [Amp 42281-1] is on the Right.
If you look at the center switch tabs you will see a hole. This is what the terminal on the Left is locking into.
Amp 179975-1
Amp 42281-1
