Hammermechanicman
- Jan 10, 2020
- Threads
- 69
- 3,908
Good info from star. Don't know if you use a chainsaw but if you do here is a link to a series of vids about proper and safe use of chainsaws. May help keep you off the Darwin awards. I work with lots of farmers clearing dead trees out of fence rows and creek banks. Most of them scare the sh!t out of me! No PPE and just doing stupid stuff.One final comment...
PT sit down and do you research...Otherwords you got some self training to do to educate yourself on bars and chains. It not something you can do overnight either it will take time absorb the info. But you probably have a few cobwebs of the mind to clear out to make room for the info too.There is times here that I got to fight my own cobwebs to retrieve things I got stored away from 20+ yrs ago.
The Oregon catalog is a good source of info; although it is limited too as you must combine your resources. I had to learn about these on the fly myself as I repaired chainsaws but now it is easy to get the right setup quickly. Of the three catalogs I got here Oregon, Rotary, and Stens; the Oregon catalog is the best when it comes to chainsaw bars and chains.
As the old saying "Knowledge is Power" is true as long as you got good knowledge and not a lot misinformation. And the internet is full of misinformation. Got to stick with the trusted sources and take everything else with a grain of salt.
Once you get the bar and chain stuff figured out it is pretty easy. If you plan to sharpen chains that is another whole thing to learn.
