Well, if you did all that then something wasn't done right or something is atypical and even though you're doing what you're supposed to be doing you're not getting the results and it's letting the procedure fail.
I have red posts over the past 10 years or so about people who have had more than one head gasket failure and it always astounds me because I have done a lot of these Briggs & Stratton 31xxxx and 33xxxx and I have literally never had a repeat failure!!
Maybe I'm just lucky but I don't think that's the case.
At bare minimum the head needs to be scraped clean with a razor blades scraper or putty knife or whatever and white clean with brake cleaner or carb cleaner or whatever and a rag and the same for the block surface. That's the bare minimum.
Then it is a must that you use the proper head bolt torquing sequence which has been revised and an accurate inch pound torque wrench.
Maybe you're rich is off one way or the other??
I want snapped a rod bolt on a 12-point headed Buick 455 engine because I borrowed a torque wrench when I was a teenager and didn't own one myself and it was calibrated way off! It must have been 25 to 30 lb minimum off because it snapped that off and I had to go to the junkyard to get another one..
So that's all I ever do and I never have failures but if I'm trying to prevent a failure I will go two extra steps..
I will place it on a flat piece of glass or very flat metal with some 60 or 80 grit sandpaper taped down..
Then I will send the heck out of it until the entire surface is even.
This of course isn't as good as actually milling one but you will quickly see the high spots and then as you keep going you're saying will start to hit the other spots so you know you have it much more flat than when you started.
It takes a long time and gets annoying. The last time I counted I had to do at least 500 strokes before I even got close to being smooth and acceptable.
Also, I do it in all different directions as I rotate it a quarter turn throughout the process multiple times.
Then the second thing I will do is spray the permatex copper spray gasket on both sides of the gasket.
Like I said I rarely do either of these and they still last for years after I put them together so I'm very surprised you're having repeated problems.
Are you using the Briggs & Stratton gaskets or the ones you get on eBay and amazon?
In this case the ones that are aftermarket could very well be better than the brakes one because it is junk from beginning and they sell you a same junk when to replace it.
I believe I saw a couple online that seemed to look like they had a fire ring around the combustion chamber which would be an improvement.
When Kohler had this problem back in the early 2000s they recalled all of their original head gaskets and replaced it with a head gasket kit, while
			If that is true about headbolts not stretching why do all automobile manufacturers in the workshop manual say to replace all headbolts on aluminum heads and even on some other uses where aluminum parts are used. I remember back in the 1960's that when taking the head of an all aluminum engine Hillman Imp you stood a good chance of breaking headbolts when taking the head of the engine to do a decoke something very few engines nowadays. I know that is about automotive but it proves the point about bolts stretching I believe.
There is no point to prove about head bolts unless you know the design parameters and the materials used of the particular head bolts and we don't.
Head bolts in the old days up until the late '80s were never TTY torque to yield.. then along came the ttys for a couple of reasons but I think mainly just they can sell more bolts.
There is a little more to it than that as they wanted to downsize everything including the holes in which these bolts resided because there wasn't as much meat in the heads and block and stuff like that around the holes so they didn't want to make the bolts as big and the bolts simply weren't as big with tons of Overkill where they can be used multiple, multiple times like many of the old head bolts on most of the engines I've built over the years were which did just fine.
They decide to use a smaller fastener and then tighten it to the point of starting to stretch so it was giving its most fascinating ability but we all know what happens then it's like a one-time use.
I don't believe these Briggs & Stratton head bolts are designed that way and I also don't believe they're very high quality either. There are some times where I can't quite get them to the new revised torque rating of 250 inch pounds without being afraid one will snap off or strip out the threads so often I don't know quite that high. It used to be 220 or 225 and now it's 250..
I think tightening in three steps which I forgot to mention in my other post, which I always do, and tightening them down evenly is more important than your final torque amount.
I have reused many of these old head bolts multiple times and I just keep them laying in a bowl somewhere they work just as well whether they've been used once or five times in my opinion.
You're not stretching them much if any and you're certainly not stretching them to yield in my opinion when you reinstall the head..
When you get good at the feel for it you can tell if one is out of whack by just using the torque wrench on it or even a 3/8 drive ratchet so maybe if one was messed up or I've been over Titan there could be an issue but other than that I think any old bolts work just as fine as buying brand new ones. Or if we could go buy some ARP head bowls I don't think it would make a bit of difference on these particular engines because it's a lousy design and a lousy gasket.
