- Feb 19, 2020
- Threads
- 118
- 12,662
One of two possibles if you only getting to run position and it blowing fuses.
1> Short in headlight wiring harness. I have seen a lot of these harness melts at the muffler area.
2> Carburetor fuel solenoid shorted.
Now of course it can any where in between the ignition switch and these areas as mice loves to chew on the wires causing shorts. Also note this assumes the PTO switch is off.
