LTX1050 just quit
bobvan
Hi, I was mowing earlier and my tractor just abruptly quit running. Now nothing happens when I turn the key. Any words of wisdom were to start to find the problem?
Bob
Battery load test, electrical grounds, gas level, oil level.
Oil & fuel levels should be checked before each use on level ground, before starting engine. See CC Lawn Tractor Service Manual page 187 below, Electrical Troubleshooting. Also inspect all belts, idler pulleys, etc. for wear.
Let's basic troubleshooting. Is any of the dash light coming on?
So I was able to spend a little time today with the tractor. The fuse was blown. Unfortunately the replacement blew as soon as I turned the key. Any suggestions on were to look for a short?
