2ball
- Jul 29, 2020
- Threads
- 28
- 136
Briggs & Stratton
17.5hp Intek IC
model 31C707-0154-E1 from 2004
I probably have a compression release issue. (probably not relevant to this thread)
I think I have a battery overcharging issue. symptoms- when I put my volt meter on my battery when its running I got 15.9 volts. I can smell battery acid, I have an issue with my battery connection and corrosion.
My old battery only lasted 2 cutting seasons and I brought it in over the winter and put it on a tender.
I can't get to my mower today its raining. I am not even sure where the voltage regulator is.
Is testing at the battery sufficient?
I bought a new battery and turned in the old battery in for the core charge with out testing it.
I did a engine swap. I am not sure I hooked up the electrical connections correctly. although it starts and runs. The lights did not work after I did the engine swap, but I am not sure the lights worked before I did the engine swap.
Can someone give me some direction?
17.5hp Intek IC
