Tiger Small Engine
- Dec 7, 2022
- Threads
- 3
- 1,427
Yes, and most of this is because of the evil youtube!
I tell people all the time to stay away from that and away from that rabbit hole because most every video I see either does things the wrong way completely or at least they do things the hard way.
Most people do come up with the proper diagnosis but that's because we can come up with that right now. About 80% of all starting and running issues on lawn mowers especially push mowers are caused from lack of proper fuel delivery specifically lack of enough fuel which is almost always caused by the carburetor not doing what it should or being as clean as it needs to be.
So they've got the diagnosis right but it's their method of going about fixing it that is either flawed or just done the hard way.
Anyone who thinks they're competent enough to take off the carburetor and install a new one should be just as competent to fix the problem and leave the carburetor still on the machine.
I literally do hundreds of these in an eight-month cutting season and I don't remove 10% of them from the mowers.
The fastest is on the old school Briggs which I can do in 6 to 8 minutes but let's just say 8 minutes max.
The new briggs takes me 10 to 12 if I'm not in a hurry.
These people on YouTube take the carburetor off and lay it out on the table and everything like that and by the time they have it all back on the machine and running they spent between 30 if we're lucky to typically at least 45 minutes.
I don't really have time for that as I have 50 other mowers sitting there to fix but regardless it's just a waste of time.
That expression works smart or not harder it's not really what I'm saying I'm saying work smarter! Work smarter and work quicker. Sometimes it is a little harder but it gets the job done and it does it more quickly and it's actually less work it's just a little more tedious work in some situations.
But let's face it, anyone who is replacing a carburetor or working on these small engines who can't handle tedious work, probably should "step away from the toolbox".
TobyU-Yes, and most of this is because of the evil youtube!
So you are saying you can successfully clean a carburetor without taking it off the mower, trimmer, chainsaw, pressure washer, generator, etc? Can you tell me how you can do this in 8 minutes? Taking out the pilot jet, main jet, emulsion tube etc.
