Bange
Is the fuel new or old?
Your engine runs lean. Did you replace your carb with a genuine Kohler carb or knock off carb? The knock off carbs are manufactured poorly therefore the air/fuel ratio is incorrect.Background:
Cub Cadet Z42
Kohler 7000se.
Had issues with the carburetor last fall & stored over winter with the carb disassembled.
This week I replaced the carb, plugs, fuel pump oil & filter.
It fired right up and but smoked a lot initially, but subsided and won’t idle smoothly.
Suggestions?Thanks
Possibility some of smoke and fuel line debris is blocking exhaust. Might check muffler and clean it outBackground:
Cub Cadet Z42
Kohler 7000se.
Suggestions?Thanks
Kawasaki engine you screw oil dipstick to left until it drops on threads then check. Briggs and a Kohler you screw in all the way. Honda take out dipstick and place it in without screwing it to read proper oil level.Did not read all the responses, had a similar problem , Tiny O rings on the main jet could be the problem idling.
The only one on your list that screw the dipstick in is the Briggs. Kohler is set on top of the threads also. There was an issue with one engine that they said to screw the dipstick in but that changed after the dipstick replacement service bulletin That engine went from 64 oz to 56 oz oil capacity.Kawasaki engine you screw oil dipstick to left until it drops on threads then check. Briggs and a Kohler you screw in all the way. Honda take out dipstick and place it in without screwing it to read proper oil level.
Engine is not running rich, it is running lean and hunting and surging. Check “smart choke” if equipped as suggested first for proper function. Then check for air leaks in intake gaskets. Then start trying to adjust air/fuel mix on carburetor if equipped. Then you have to drill out jet as last resort. Aftermarket carburetors on Kohler engines specifically are hit and miss. Otherwise, this engine will never run right or make proper power. Or, get original carb working properly or bite the bullet and buy sniOEM carburetor.
Yes, and most of this is because of the evil youtube!He probably took the carburetor off because everyone often seems to think it’s the carburetor. So the parts changing begins…
