shadetree#1
- Oct 31, 2022
- 153
Does your owners manual show a Tecumseh part number for the starter?
Does your starter have a Tecumseh part number on the casting or otherwise?
(tecumseh sometimes has a part number stamped on their starter. See if the number on the starter matches the part number on your owners manual parts list and post up the info)
Sometimes you can locate a starter/alternator/generator repair/rebuild shop that has been in business for long time and get a repair estimate or tips on re-glueing the magnet. The magnet has to be re-installed with the SAME exact POLARITY as before. If re-building that starter the commutator needs tested on a growler to see if it's ok so as to know YOU are not whipping on a dead horse.
