As with even soldered wires you must stagger those connection points. Those splices are not much bigger than the 16 ga wires with insulation. The only difference is the heat shrink.There is a harness with multiple wires. If you put several of those, they add up.
Well you are a few hundred harnesses behind me then. Plus I have doing this for 40 yrs now.I did not stagger anything. I solder and shrinktube them. I spliced wherever they were cut. That was the 2nd wiring issue I had that was repaired. The first was the stator wire that was too close to the flywheel, was sheared off. Clean cut like a razor cut. I had ordered a new stator, and when I went to replace it, I found the sheared wire and realized the stator was still good. I replaced it anyway, and re-routed the 2 wires. The wiring on these mowers left a lot to be desired as far as quality. They seemed put together with carelessness and sloppiness.
Um, no. I'm probably well ahead on you with working with harnesses. You see, wiring harnesses are in everything electrical/electronic. I have soldered far more wires and harnesses (since early 1980s), then you never ever crimped. And the one thing I have learned about soldering wire, that it is superior to the cheesy crimps that you use. Especially when you take oxidation resulting from being exposed to the elements. Another thing I learned in my 40+ years, is that the reason people don't solder, is because they can't. Not impressed with your 40 cheesy years. LOLWell you are a few hundred harnesses behind me then. Plus I have doing this for 40 yrs now.
What a crap job. LOL. You charge people for that? LOLAs with even soldered wires you must stagger those connection points. Those splices are not much bigger than the 16 ga wires with insulation. The only difference is the heat shrink.
But here an image of two 16ga wires joined by the splice. I don't think there is much bulk there
OK you twoWhat a crap job. LOL. You charge people for that? LOL
