- Feb 19, 2020
- Threads
- 120
- 12,800
Only one problem there as some Craftsman mowers that used the 420000 series even with same type numbers were label as at least three different hp rating. I know definitely to this as I had three Craftsman mowers in the my shop the same week that were label 18.5, 19.5, and 20.5. All three were sitting side by side.if you can tell us whattractor model number this came off of there will be info on the engine hp rating which can help identify the model 42 or 44 or 46...
But if a Craftsman then the owners manual might give us a model number. The problem there is the engine maybe a transplant engine so that may not even work.
